Coaxial cable internet wrong frequency
39 minutes ago, JoeyDM said:They used a wrench for it.
It could also be that the coax cable is bad. Or something else entirely that I'm not guessing.
Ok, so i tried screwing the coax cable into my data port harder with pliers, no effect, then i tried screwing it harder into the modem, no effect, then i browsed the web on my shitty phone connection speed for about 1 hour, and found a manual from some wierd modem where they said that you could try factory resetting your modem, and it would maybe work, so i did it and nothing happened for about 1 minute after it restarted, then all of the sudden the modem got internet acces again and the peasants rejoiced
Thanks for all the help, it was a pretty scary thought to not have an internet connection over a weekend
