Hello, so I recently re-installed windows and when i booted my PC up, my Cpu cooler fans were spinning at max and I wasnt sure why or if this was a bug. So I opened corsair link and real temp and they both told me this.
https://gyazo.com/ceeb97c96c54cb27d82fb435829e05ea
Not sure why the temps are this high seeing as there is currently no OC applied and no applications are running.. Please help.
  • CPU: Intel Core i7-6700k @4.3ghz, Motherboard: Gigabyte Z170X Gaming 7, RAM: Corsair Vengeance LPX 16GB @2400mhz, GPU: Gigabyte GTX 1080 G1 , Case: Corsair 300R, Storage: Samsung 850 EVO 256GB SSD, WD 1TB Black HDD, WD 2TB HDD PSU: Evga SuperNova 750 G2, Display: ASUS VG248QE @144hz, Cooling: Cooler Master V8 GTS, Keyboard: Corsair K95 RGB Platinum, Mouse: Logitech G502 Lightspeed, Sound: Phillips SHP9500 + VModa Boom Pro, Operating System: Windows 10 Pro
https://linustechtips.com/topic/577929-extreme-temperature/
ssssssssshhhhhhhhhhhhhhhhhhhhhhh
ive never seen  a core get 200C what the hell!
Reboot?
if not check the,.... oh no you are using an aio that shouldve been suffecent.
https://linustechtips.com/topic/577929-extreme-temperature/#findComment-7557863
I rebooted but nothing has changed.. Gaaaah
https://linustechtips.com/topic/577929-extreme-temperature/#findComment-7557891
Just tried using the program to turn the fans down but it wouldn't  budge the speed?
https://linustechtips.com/topic/577929-extreme-temperature/#findComment-7557896
@LinusTech any suggestions? Someone help!
https://linustechtips.com/topic/577929-extreme-temperature/#findComment-7557983
Use HWMonitor or HWinfo to confirm that the Corsair Link software isn't just bugging out. If it is, uninstall and reinstall.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/577929-extreme-temperature/#findComment-7558130
The thing is, both the bios and real temp both say the same thing, and I have already tried uninstalling and reinstalling corsair link and it did absolutely nothing.
https://linustechtips.com/topic/577929-extreme-temperature/#findComment-7558597
Could I have to reseat my cooler?
https://linustechtips.com/topic/577929-extreme-temperature/#findComment-7560149
