Tt poseidon: double-click issue
Solved by paprikman,
Okay, so I finally solved this issue. Just posting it in case someone will face same problem and will be looking for the solution.
Since the spacebar switch was broken (double-click) and I didn't want to buy new keyboard or new switches, I replaced it with the "scroll lock" key switch - it was easy and quick. Everything's fine now.
1
5
1
toxic_worper ·
9
1
voltigeurramon ·
Posted in Troubleshooting2 -
1
1
