Hello community members, I have this build ready to be ordered in 30 minutes and I tried my best to be cheaper. I can't do much since my budget is really tight, too many other fees here in Australia :P
Storage doesn't really matter as I will transfer both my SSD and 2.5 2tb HDD from my laptop (Sh!t box)
https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=559524&action=wish_lists
What the hey....
https://linustechtips.com/topic/577498-first-custom-build/
ok, few things:
1. you don't need a fully modular PSU!
2. R9 380 is cheaper and will perform better than a gtx 960
so for better value, i would get an r9 380, and a semi-modular psu, and it will be a bit cheaper (maybe you can save around 30-50 bucks)
have a good one! xD
R5 3600x | RTX 3070 | 16Gb 3200mhz | Gigabyte B550 gaming x | 500gb 660p SSD + 1tb wd blue HDD |
https://linustechtips.com/topic/577498-first-custom-build/#findComment-7553262
Comparative build:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($279.00 @ PCCaseGear)  <<100MHz is not worth the extra $40
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler  ($39.00 @ PCCaseGear)
Motherboard: ASRock H110M-ITX Mini ITX LGA1151 Motherboard  ($119.00 @ PCCaseGear)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($108.00 @ PCCaseGear)
Video Card: MSI Radeon R9 380 4GB Video Card  ($339.00 @ PCCaseGear)
Case: Corsair 380T Mini ITX Tower Case  ($185.00 @ PCCaseGear)
Power Supply: XFX XTR 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($129.00 @ PCCaseGear)
Total: $1198.00
Generated by PCPartPicker 2016-04-06 18:32 AEST+1000
https://linustechtips.com/topic/577498-first-custom-build/#findComment-7553284
1 minute ago, Lolicon_Pasta said:
I did all the things and it was a bit cheaper, although when I used the R9 380... It was a lil pricy xD
oh, yhea, i didn't check the prices in australia... Maybe i should have checked the price difference between those gpu's there...
https://linustechtips.com/topic/577498-first-custom-build/#findComment-7553296
2 minutes ago, Lolicon_Pasta said:
haha, that's alright :P
Well check out this case.  It is really nice, aluminum (look)too:
Case: RAIJINTEK Metis (Red) Mini ITX Tower Case  ($59.00 @ PCCaseGear)
Total: $733.00
Generated by PCPartPicker 2016-04-06 18:38 AEST+1000
You have to fit a GPU in it though.
https://linustechtips.com/topic/577498-first-custom-build/#findComment-7553308
2 minutes ago, stconquest said:
Well check out this case.  It is really nice, aluminum too:
Total: $733.00
That one looks good :D
You're from the eastern part of the country huh xD
What the hey....
https://linustechtips.com/topic/577498-first-custom-build/#findComment-7553316
