my computer are freezing randomly whitout warning.
the freezing is somtime 1h from computer start and somtimes it takes a week before it freezes.
i hawe noted it freezing under mid load aswell as idling
i did think it could be the ram that was faulty but i hawe run the ram diagnostics tool in windows and memtest whitout any problems found.
i hawe reinstalled all my drivers and tryed a reinstall.
but nothing helps, so now im here asking for help whit my problem and hopes for a solution
thx in advance
specs:
cpu: i7 -3770
ram: kingston 4x4 16800 MB/s
motherboard: asus Z8Z77-V LX
grafix: xfx radeon r9 380
psu: xfx 750 w
os: win10
https://linustechtips.com/topic/577492-help-compueter-freezing/
Reset all overclocks (if overclocking)
does it show a blue screen of death, if so post picture
watch your temps right before the crash
check if mobo faulty
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553135
Hard drives are a notorious cause of freezing, especially if they're in the early stages of failure.
Perhaps someone here can recommend a hard drive benchmark that can graph a read-out of entire disk.  Or at the very least, run something like CrystalDiskInfo or smartmontools (if you're on  Linux) and it will tell you if there's something noticeably going on with the disk.
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553161
might be, but i hawe done daily defrags whitout anny signs of crash and run cmd command "chkdsk"
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553170
Perhaps so, but I've seen a few cases where hard drives will just take a bit longer than usual when reading certain blocks.  Particularly in the early stages of failure, they can often, with appropriate error-correcting codes and retries, recover data.
Not saying this is applicable to your situation, but a mere chkdsk or bad blocks scan in Windows (or fsck in Linux) wouldn't detect such performance degradation and impending failure.  Even the SMART statistics may fall silent unless you are really good at trending and interpretation.
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553177
Not saying this is applicable to your situation, but a mere chkdsk or bad blocks scan in Windows wouldn't detect this behaviour.
will try difrent kinds of hdd programs when i get home to my computer. if annyone know a good free one fell free to post it here and ill come back when tested
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553182
What hard drives you running in that anyways?  4 years ago, hmmm, were people still building machines with HDDs as boot drives?  I'd have to think so.  There were lots of less-than-savoury, prone-to-failure SSDs, particularly from OCZ, sold around that time as well.
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553198
1T mechanical hdd from sergate. bought about 3-4 years ago
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553204
Ick, yeah those Seagates from that era were notorious.
Even if its not the drive gone/going bad, seriously, get a SSD!  Best computer upgrade you'll ever spend money on.
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553209
Try putting your gpu in another pcie slot. Could be a damaged slot or pcie lane/trace. That fixed the same problem for me in my last build.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553229
agred i hawe been haweing ssd in thoght for a while now, but as long as my hdd is working and i dont finnd somthing wrong. dont wanna spend the money on a ssd yet.
found a 3-party program ill try later called CrystalDiskInfo and a smd command  "wmic"       "diskdrive get status"
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553233
can the gpu rly be a problem when it dosent even bother when i push it to the max and some of the freezes hapend when it was on idle??
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553239
Yes. It would work fine for hours in thief, but shit itself in harthstone. It isn't the gpu, but could be the slot
My rig:
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553242
will try switching then, even thoe it runs smotly in all games i tryed so far
It's worth a shot. I'm not saying it is the cause, but it was when I had freeze problems. Best of luck
My rig:
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7553255
well iv trired to run CrystalDiskInfo and it says ym drive is good still so i will take its word on that. did some small gothro deleting some unecesary programs.
will w8 for next freeze untill i try switching the slot for my gpu
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7554670
  • 2 weeks later...
since i switched my gpu to another pcie slot it stoped freezing.
but my games now run slower than ever before.
annyone know of annyway to clean/reapair the pcie slot?? looked inside and saw a white spot at the beginning of the lane (could just been the light from my camera but not sure)
https://linustechtips.com/topic/577492-help-compueter-freezing/#findComment-7614489
