I have an idea for a basic build like for everyday work, but is this a good starter workstation???
Hardware list:
CPU: Intel Pentium G4400 "Clocked Speed:3.3 GHz" Dual Core Skylake.
CPU Cooler: Cooler Master Hyper 212 Evo 82.9 CFM sleeve
Motherboard: Gigabyte GA-H110M-A LGA1151 Socket
Ram: Crucial 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 2133
Hard Drives: Kingston SSDNow V300 Series 120gb 2.5", 1TB Western Digital Blue.
PSU: EVGA 500W 80+Bronze certified PSU
Case: Corsair 200R ATX Mid tower case
This build cost in total: $338.85 USD
Base Total: $368.85 USD
Hard drive question: Should i get a 1tb Western Digital Blue
https://linustechtips.com/topic/577343-basic-build/
Just now, Sanderman135 said:
For basic everyday things like watching movies, typing papers, etc this build would be perfectly fine. But as a workstation? I don't know. What are you planning on doing with it specifically?
Also the WD blue drives are some of the best.
I'd like to complete @Sanderman135's answer.
WD Blue drives are great for day-to-day use, for instance browsing. Storing pictures etc.
WD Black drives are more for performance.
WD Green drives are more power efficiënt and will live longer than Blue drives if you're not going to use it for storing games and lots of Read/Write operations then this one will be fine as well.
https://linustechtips.com/topic/577343-basic-build/#findComment-7551445
3 minutes ago, Talia_meh said:
With this system i planed to edit video since me and my group of friends want to start on youtube.
A blue/green drive would be fine, unless you are going to do high or ultra HD (4K) Rendering at high bitrates and stuff, then you would better go with a Black for the performance.
https://linustechtips.com/topic/577343-basic-build/#findComment-7551466
Welp then i would go for those build
Please don't listen to fags who say you cant video edit on pentium
yes it will be harder because slower rendering and stuff but doable
I video edited on my pentium before as well.
Instead of skylake get a G3258 so you can overclock and get higher clock speeds
PCPartPicker part list: http://pcpartpicker.com/p/QLRYpg
Price breakdown by merchant: http://pcpartpicker.com/p/QLRYpg/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($65.99 @ SuperBiiz)
Motherboard: Asus B85M-G R2.0 Micro ATX LGA1150 Motherboard  ($65.98 @ OutletPC)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($28.99 @ Newegg)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($35.89 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.64 @ Directron)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($36.99 @ SuperBiiz)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $338.47
Generated by PCPartPicker 2016-04-05 19:26 EDT-0400
Insert   Dank   Signature   Here.
https://linustechtips.com/topic/577343-basic-build/#findComment-7551468
the problem is that unless your really hardly planning on upgrading the cpu isnt a good choice.
it has no hyper threading so you only have 2 logical cores. the amd 4 cores would be way faster
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/577343-basic-build/#findComment-7551475
Just now, TheAmazingCookieFromSquare said:
for video editing the amd's are better. you simply have no hyper threading. the anniversary (highly overclocked) might be faster in some games (if you can get them started with 2 cores) but for video editing its slower
https://linustechtips.com/topic/577343-basic-build/#findComment-7551485
Looking at the end-price I'm shure he's on a low budget, he doesn't have a GPU anyways.
This would work perfectly fine as I do render video's for friends myself on my G3258 @ 4.7 GHz and it never bothered me as I would do it over midnight anyways.
https://linustechtips.com/topic/577343-basic-build/#findComment-7551489
True if you want to video edit go get a athlon-860k
https://linustechtips.com/topic/577343-basic-build/#findComment-7551490
I'd like to note that my G3258 Bottlenecks my R9 270 but still runs GTA 5 at medium 60 fps well enough :)
https://linustechtips.com/topic/577343-basic-build/#findComment-7551496
im sure you can do it but the amd is faster
https://linustechtips.com/topic/577343-basic-build/#findComment-7551502
its ok but for editing its just slower
https://linustechtips.com/topic/577343-basic-build/#findComment-7551503
That clock speed is higher then a 6700k i7
https://linustechtips.com/topic/577343-basic-build/#findComment-7551513
athlon x4 485 with the new cooler so he saves money on the aftermarket one. for display you can basically use a usb adapter or any ebay cheap gpu
https://linustechtips.com/topic/577343-basic-build/#findComment-7551521
athlon x4 485 i could just throw in a gtx 750
thats good you could do video acceleration
https://linustechtips.com/topic/577343-basic-build/#findComment-7551555
AMD FX-4300 Maybe?
Clocked at 3.8GHz, 4 Cores on the AM3+ Socket
Around ($ 87.55, European calculation)
problem is that its 32nm an only 200mhz faster. i would really go for the 28nm just for the cooler alone. also mobo on fm2+ are cheaper
https://linustechtips.com/topic/577343-basic-build/#findComment-7551576
I'm not a AMD CPU/ AMD socket expert, never used before, never will. Just an opinion :)
Though thank you for telling, this could be usefull later good on mate!
https://linustechtips.com/topic/577343-basic-build/#findComment-7551581
