Hello,
So, I've recently rebuilt my PC, and people have been warning me on my choice of power... I grabbed a nice GTX 970 (link below) and an EVGA 500W PSU (link also below.)
GTX 970:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487088
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438016
The rest of my build is a gigabyte P55 USB3 - i5 750 (OC at 3.4 GHz) - 8GB's ram (2x2GB G-Skill Ripjaw 1333) (2x2 Corsair XM3 1333) - 2 SSD's and a 500 GB Sandisk 7200 RPM HDD.
I was wondering if my build would suffer from a 500W power supply, or if it would cause any future potential harm? I've been using it for about 2 weeks or so now. I've been playing The Division, and I've done some hard gaming hours at a time with no shutdowns, crashes, etc. It seems fine, I just want to know if it may be a problem in the future.
Any insight would be helpful!
Thanks,
Ricky
https://linustechtips.com/topic/577016-gtx-970-power-consumption/
I've got a 970 and a i5 4460, plus a heap of LED's and peripherals, and barely break 250 watts. You should be fine.
CPU: Core i7 7700K | GPU: EVGA GTX 970 SC ACX 2.0 | MOBO: Asus Prime Z270-AR | RAM: 16GB Corsair Vengance LPX | PSU: Corsair RM850i | HDD: Seagate Barracuda 2TB | SSD: Kingston 128GB SSD & Samsung 850 Evo 500GB | Cooler: Corsair H100i GTX | Case: CoolerMaster Mastercase Pro 5
970 uses around 200-220W depending on the clockspeed and power, as for the PSU, that one is AWFUL - get something better ASAP
Check with @STRMfrmXMN 's whitelist or @Aniallation 's ranking and tiers
8 hours ago, S1ickRick said:
Hello,
GTX 970:
PSU:
Thanks,
Ricky
500W is plenty but that PSU is for very basic systems, not high-end GPU systems like with a 970. Get something from the PSU whitelist in my sig. The EVGA B2 and GQ can often be found cheap.
