6 minutes ago, Jonathan Fredrick said:
Will the Asus Gtx 970 Strix fit in the Corsair Obsidian 250D? cuz the card looks like it would be too high for the case when an optical drive is installed..
Since it's a corsair case, I'm guessing yes, they'd want all standard cards to fit.
Edit: Yes, it does ( http://pcpartpicker.com/p/JRty8d )
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
The gpu length for your 250D Mini ITX tower case is 11.42 inches while the gpu is 11.02 inches
It should fit
Your case:
https://pcpartpicker.com/part/corsair-case-cc9011047ww
(Hopefully) Your GPU:
https://pcpartpicker.com/part/asus-video-card-strixgtx970dc2oc4gd5
Don't call me a nerd, it makes me look slightly smarter than you
Yes you will have 1cm of clearence judging from the specs. 28cm of strix for 29cm of space.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
