if it is crashing you might want to consider increasing the voltage limit, also check your temps and make sure its not too hot.
Buy my yoga 2 pro!  http://linustechtips.com/main/classifieds/item/2711-lenovo-yoga-2-pro-i7-4510u-8gb-ram-4k-btc-accepted/
[spoiler=Trumps Wall
]AMD FX 8320 OC@ 4.4 GHZ GPUamd sapphire 7950RAM: 12GB CORSAIR XMS3 Psu: Corsair cx 500m CASE: Corsair 800d MOBO: Asrock 970 extreme 3 r2 Storage: 256GB mx100 SSD, 1TB WD Blue,1tb Seagate Barracuda in Raid 0, 750GB Seagate Baracude. Os Windows 7
CPU: AMD A-10 5800k RAM: 4GB DDR3 Storage:Random drives Mobo:msi SomthingCase: good question
increase voltage (not to exceed a safety level, not sure what it is for AMD but its normally 1.35v for intel skylake), while monitoring temp, make sure it doesnt get too high
if its still unstable
lower clock speed, your processor isnt going to go further
-sigh- feeling like I'm being too negative lately
i had it pushed to around 1.4400V and it wasnt going higher than 50 degrees
your motherboard isnt that great for OC anyway, maybe its just not going to go higher
