Hi, after watching Corsair's video about installing this AIO, I realised that I have to connect the pump cable to the cpu header of my mobo, the problem is that my mobo(MSI H97-E35) has one cpu header(4 pin), another header which is 4 pin but it is fried, and one SYSfan 2 which is 3 pin. I am running 3 fans from the PWM header with this adapterhttp://www.frozencpu.com/products/13548/cab-464/Akasa_Flexa_FP5_PWM_5-Way_Splitter_-_Smart_Fan_Cable_AK-CBFA03-45.html.
My questions is, can I connect the pump header to the PWM splitter and still control the pump?
https://linustechtips.com/topic/576488-help-installing-h110i-gt/
The pump cable is a sata power cable, and the header is there to stop you getting a no CPU fan error and the fans just plug into the two fan headers coming from the pump
i5-6600k @ 4.9Ghz | Corsair H110i GTX + 2 x Noctua NF-A14's | ASUS Maximus VIII Ranger |
Corsair Venegance DDR4 8GB | ASUS GTX 970 Strix |Samsung 840 EVO 240GB + 1TB HDD |
Corsair RM850 | NZXT H440 Black | 2 x Noctua NF-F12 + Corsair AF-140
https://linustechtips.com/topic/576488-help-installing-h110i-gt/#findComment-7541873
So, I don't need to connect the header since I am using the CPU header for my fans right?
https://linustechtips.com/topic/576488-help-installing-h110i-gt/#findComment-7542303
No you can just leave it
https://linustechtips.com/topic/576488-help-installing-h110i-gt/#findComment-7542317
