Adobe Premiere Pro Help!
Solved by GreezyJeezy,
5 minutes ago, Jech said:I'm making a start of a video that uses text to introduce the video, and when I insert text and center it, and then go to add more text the old text pops up in the editor panel and I can't change it? What do I do?
does it use layers? if it does lock the layer that the text is on and then put the other text on a new layer. all of the adobe stuff i use has layers so its just a guess that premiere does.
