I have two EVGA GTX 980 TI Classified 2.0+ Graphic cards and they plug in with two 8 pin connectors each from the power supply
But both Graphic cards came with two 8 pin connector that plugs into the power supply and it splits into two 6 pin connectors
and im very confused about this....
How to I plug these Graphics cards up....
https://linustechtips.com/topic/575733-need-help-installing-graphic-cards/
No 8-Pin connector, no fun.
Do you have a 6+2pin connector cable? You might want to buy on if not.
Oh wait. That thing is an adapter from 2x6pin to 8pin.
Ther should be 8 pin connectors that came with your AX1500, A LOT of them!
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
I know my 860I came with a 6+2 & 6+2 on the same cord.
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
Would this connector work?? or would that supply to much wattage through the same cord??
or am I over thinking it lol
Yes that would work.
