On that board, they will already be spaced apart from eachother.
Was there a particular expansion card you wanted to put in between them? Because otherwise the first and second slots are already spaced far enough apart to have a whole space between the cards.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/575434-sli-help/#findComment-7532051
Ya I guess your right
This is my first build so I probably am over thinking it lol
https://linustechtips.com/topic/575434-sli-help/#findComment-7532052
No problem :)
Better to over-plan it than under-plan it. I think that space should be good enough.
https://linustechtips.com/topic/575434-sli-help/#findComment-7532059
