Hello everyone!
My litle brother was done with his old rig so he left me a swiftech h220.
So i took it cleaned it and put it in an old rig i have laying around.
I turned it on and there it was 'pssssss' white smoke, The black wire burned.
ive never used watercooling before but understand the basics, so yes it was filled etc.
now for the Question part:
The rad of the 220 is pretty good i read, so i wanne re-use it.
can i use the cpu block of the 220 (maybe clear the rotor/magnet out and put a pump to it?
ow and any recomendations on what pump to get for it? (pref cheap but decent)
Thanks in advance!
CPU: AMD Phenom II x6 1090T black editon. Graphics: ASUS GTX 780 DirectCU II OC. Ram: 8 gig ddr3 1333 Mhz
https://linustechtips.com/topic/575115-swiftech-h220-pump/
yeah DDC pumps are crap, they burn out often
you cant use the rad without a pump there though, since its all one piece
that means you either need to buy another DDC to replace your fried one or buy a good pump (D5) and new radiator
https://linustechtips.com/topic/575115-swiftech-h220-pump/#findComment-7529125
The rad is yust a rad the pump is on the cpu block. so i dont get it..
https://linustechtips.com/topic/575115-swiftech-h220-pump/#findComment-7529350
oh youre using that cooler...
that ones really old lol
yes you can use the CPU block but you will need to use an external pump
the pump inside the CPU block will restrict flow and cause noise, so its recommended you buy a new CPU block
the rad is fine to use
https://linustechtips.com/topic/575115-swiftech-h220-pump/#findComment-7529402
