You gave us too little info.
My guess is you didn't plug in the video cable correctly. Make sure you didn't plug it half-way, that the screws (if you have) are tight and check whether you plugged it into the motherboard or the external GPU.
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/575079-pc-wierdly-not-booting/#findComment-7528732
Gpu is in and we tryed with multiple wires abd nothing.
Its not giving singnal.
https://linustechtips.com/topic/575079-pc-wierdly-not-booting/#findComment-7528767
Gpu is in and we tryed multiple wires and nothing.
https://linustechtips.com/topic/575079-pc-wierdly-not-booting/#findComment-7528769
Can you give me your system info?
My rig:
HDD: Seagate 500GB
RAM: 1GB DDR3-800
HDD: HGST 320GB
https://linustechtips.com/topic/575079-pc-wierdly-not-booting/#findComment-7528795
1 hour ago, Xusu said:
Motherboard: Asus f1a75-m
Gpu: amd radeon hd 5870
Cpu : i5
Powersupply: 350wat chiniese piese of shit cos the old one broke.
The 350W PSU maybe insufficent
My rig:
HDD: Seagate 500GB
RAM: 1GB DDR3-800
HDD: HGST 320GB
https://linustechtips.com/topic/575079-pc-wierdly-not-booting/#findComment-7529156
