Hello, so I turned on my computer today and I couldn't get a signal from my gpu. All the fans and lights are on but I'm still not getting a signal is there a way to check if the pci slot is broke? Or does anyone have any idea why it would be doing this? Idk if the picture below means anything but yeah I put it there just in case it does
1459523638637-224069110.thumb.jpg.6fca69
Specs: Intel i7-4790k | Corsair H60 | Asrock Z97 Pro4 | 4x4g Corsair Vengeance | Gigabyte g1 970 | Sandisk u110 128GB SSD | 1TB Toshiba Hard Drive | Corsair RM750 | Corsair Air 540 4 Corsair AF120 LED Purple 2 Corsair AF140 LED Purple
https://linustechtips.com/topic/575049-no-signal/
if it's the pc in your sig remove the gpu and see if you get signal from the intel graphics from your processor
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
https://linustechtips.com/topic/575049-no-signal/#findComment-7528339
24 minutes ago, GreezyJeezy said:
Are the Gpu fans on
Yes
I did and I got something a signal
https://linustechtips.com/topic/575049-no-signal/#findComment-7528458
