Hey there everyone, I'm a newbie and I'm gonna build my own PC soon. I haven't had much experience with hardware but I've made some solid choices. I'm going to use the 980ti from Nvidia, but I don't know what cooling I should get. Should I get MSI Twin Frozr Vs or maybe ASUS Strix? I do't know. Please help me. Help will be very much appreciated
https://linustechtips.com/topic/575037-best-graphics-cooling-solution/
personally i like getting the cheapest version of what ever card i like ie reference r9 290x used and slapping a kraken aio on it.
CPU: I7 8700k @ 5ghz | Motherboard: Asus Z370-Prime | RAM: White Crucial balistix DDR4 2133mhz | GPU: GTX 1080TI | Storage: ssd HyperX 240gig, 2x2tb seagate Firecuda 1tb, BPX 480 gig nvme, 1tb sandisk ssd  | Cooling: Custom loop | PSU: Evga supernova 850w G2 | Case: Phanteks enthoo evolv atx black White modded | system theme: White/RGB/Weiss
1 minute ago, Aytex said:
EVGA Hybrid
EVGA FTW
Msi twin frozr
Gigabyte extreme
any of those are great
How about the Hydro GFX from Corsair, I checked JTL's channel for the review and it had a pretty good clock speed. And many people use ASUS Strix. What are your opinions about those two?
This is the one with MSI+ corsair correct?
if it is the Hydro GFX has a higher clock than the EVGA Hybrid if i recall, i think you may get more preformance
i was going to put it down but i forgot the name :P
Yep, thats the one Im talking about. The Corsair and MSI GPU. Thnx
You could go all out and get the Zotac Amp! Extreme with its 3 slot cooler :P I got mine to 1520mhz.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
14 minutes ago, Aytex said:
yea its called msi seahawk as a product, go for it
Nice! Do you guys have any experience with ASUS cards? Im using an ASUS ODD and an ASUS Motherboard. Its easier to get in my location.
They are eh, not the best
there are way better ones that are worth the money
2 minutes ago, Master Jimbob said:
Ok thanks. Then I think I'll go with the EVGA hydro, Hydro GFX or MSI Twin Frozr V
EVGA Hybrid, i've actually used before, its good, plug and play they have great customer support
Hydro GFX should give you a little bit more fps than the hybrid
the twin frozr is eh compared to two AiO just in terms of looks lol
K Then, Hydro GFX it is.
the actual name of that card is the MSI Seahawk, if your buying it from somewhere else than corsair's website
they made 2 names for it which makes it confusing as fuck
This will probably go well in my Corsair 250D case. Though do you think that I well be better off getting a EVGA air-cooled 980ti, but with the Corsair water-cooling adapter and a Corsair H90? Becuz the Hydro GFX is using the H55.
You can if you want, EVGA FTW is really nice if you want to get aircooled
