Help with ram speed
Go to solution Solved by Oshino Shinobu,
DDR = Double Data Rate.
800MHz x2 = 1600MHz effective clock.
The RAM is actually running at 800MHz, but performs two operations per cycle, so the effective clock is double that of the actual clock.
Each stick is 800MHz, times two gets 1600MHz, this confused me for a while with my RAM, then I realised that each stick was running at 1200MHz for a combined 2400MHz.
        Pixelbook Go i5 Pixel 4 XL
https://linustechtips.com/topic/574577-help-with-ram-speed/#findComment-7523444
