Problems With CPU
Go to solution Solved by Nohemi,
12 minutes ago, Nohemi said:
okay i found the problem, I just needed to enable multi-core enhancement mode (I think it was called that)
Hi
So this has happened to me before, but I forgot how I fixed it. It was the kind of thing where I just changed a whole bunch of settings and it magically fixed the problem. Anyways, my computer is super slow. For some reason it only uses like 2% CPU to do everything. I have a G3258 Pentium and a ASRock Extreme 3 mobo, help.
https://linustechtips.com/topic/573706-problems-with-cpu/
Check your power plan settings in the control panel. Set it to high performance and then edit the plan, check cpu max state.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/573706-problems-with-cpu/#findComment-7514624
