I started building a pc for a friend. Heres a link to the build: https://pcpartpicker.com/user/TRambo/saved/PP6WGX Inside the case we are using one 140 mm fan in the back, a 280mm aio cpu cooler on the top with two 140 mm fans and then there is one 120 mm fan on the side of each hard drive cage. Should i leave the fans on the hard drive cages like they are or should i rotate the hard drive cages so the fans are facing the front of the case? Heres a link to the case: https://pcpartpicker.com/part/cooler-master-case-sgc5000kwn1
https://linustechtips.com/topic/573314-cooler-master-stormtrooper-airflow/
