1 hour ago, Xx_death1544_xx said:
I have about 50 of these small Solico lights i used when i wired up my machine shop (I used them on the breaker switches to tell if they are on) and i cant think of anything to do with them so i was wondering if anyone had any ideas.
Time to make the shop light up like NYC :D
Maybe something like an old signs like they did with those mini tungsten light bulbs
https://linustechtips.com/topic/573258-solico-lights/#findComment-7510023
I think I will that would be very easy to make because that are ac so they would plug into the wall and I would just have to drill holes in a peice of metal in the shape of the letters
https://linustechtips.com/topic/573258-solico-lights/#findComment-7510045
Yeah that sounds very doable and quite easy to power up.
https://linustechtips.com/topic/573258-solico-lights/#findComment-7510082
