Ok so i have this card for a while now,and like 2 months ago it started acting wierd or at least i think its the cards fault.
My pc suddenly freezes and i have to reset it, or sometimes i get BSOD and it says driver stuck in infinite loop.
The card is asus r7 260x oc 2gb ddr5.
What do you think guys? I tried reinstaling the driver and installing again nothing changed,same problems remained.And im getting messages with solve ati raden graphcis driver problem.Driver has stopped working 29 times in action center messages.
And i just saw that a new driver is avaiable released 28.03.2016.I hope it will help me,but first i wanna hear what you have to say.
Thanks in advance
https://linustechtips.com/topic/573082-problems-with-r7-260x/
I'd think you'd want to update to the latest driver.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/573082-problems-with-r7-260x/#findComment-7507773
7 minutes ago, Duh_tech said:
To be honest AMD kind of stinks when it comes to quality.
It's an Asus card... Also AMD's quality of products are just as up to par as any other tech company. What basis do you have to justify that statement? Please do not start another flame war. Post facts and not personal gripes/bias's.
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
https://linustechtips.com/topic/573082-problems-with-r7-260x/#findComment-7507812
Just now, Lonko said:
ye gotta try that since it came out today
Give it a shot and come back if that didn't fix the issue. Keep us posted.
https://linustechtips.com/topic/573082-problems-with-r7-260x/#findComment-7507817
And the quality of your comments, too.
_____
The first thing I would do is to comepletly reinstall drivers by using the Display Driver Unsintaller: http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Then I would download the newest driver and install that.
If that doesn't help, try the graphics card in a different slot on your motherboard. Maybe the PCI-e slot on your motherboard is defective.
You can also try to run on the integrated graphics-chip of your CPU if it has one, by simply unplugging your graphics card and plugging your monitor into the back of your motherboard. If it still crashes under the same circumstances, then you know at least that it isn't the fault of your graphics card.
https://linustechtips.com/topic/573082-problems-with-r7-260x/#findComment-7507818
_____
im using a i3 540 i dont know if it has onboard graphics.
https://linustechtips.com/topic/573082-problems-with-r7-260x/#findComment-7507827
14 minutes ago, Senzelian said:
Yes it has. It's an older chip, but will work fine.
Every i3, i5 or i7 has onboard graphics.
Not all of them have onboard graphics. The very high end I7 extreme editions don't have it.
Duh_Tech
I am a computer and aviation enthusiast. I have a good enough PC.
https://linustechtips.com/topic/573082-problems-with-r7-260x/#findComment-7507924
