PC running through iMac
Go to solution Solved by Ningols,
I'm not sure you can use a iMac as a display for a pc, but I know that you can use an iMac as a display for other macs using thunderbolt
But, as the 21" iMac is 1080p and the 27" is 1440p, you'd pay less for a real monitor
So my cousin is looking to sell his iMac and im very tempted, it has two thunderbolt on the rear and im woundering if it is possible to run my computer through it in target display mode, my GFX card in my pc has a DisplayPort HDMI and two DVIs
https://linustechtips.com/topic/573046-pc-running-through-imac/
not it is not possible
those are display outputs
you cannot repurpose an iMac as a monitor, sadly
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/573046-pc-running-through-imac/#findComment-7507462
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/573046-pc-running-through-imac/#findComment-7507478
Gaming rig : i5 6600k | EVGA 1070 FTW | 16Go DDR4 HyperX Fury | Intel 600p - WD Black
Laptop : Macbook 2017
Home server : AMD A10 7700k | 2*2TB unraid array + 250GB ssd cache
https://linustechtips.com/topic/573046-pc-running-through-imac/#findComment-7507489
