Replace Define R4 LED
Solved by W-L,
Just now, Chuck38 said:Okie dokie, thanks.
Would this work? http://www.amazon.com/3mm-LED-Bulb--Red-Pack/dp/B003KWDVHY/ref=sr_1_1?ie=UTF8&qid=1459125132&sr=8-1&keywords=red+3mm+led
Yep those should be good, you might need a bit of hot glue to hold it into the plastic housing but other than that it should be fairly straight forward.
