Ive been working on a college project for a currency converter, and I want to add a drop down menu to choose which currency to convert from &t o. Im using visual studio 2015 community edition, could somebody let me know some code or some sites which could help?
My Build: G3258 OC@4.4GHz - Raijintek Aidos - 8GB Ballistix Sport - H81M-S2H - ASUS R7 250 1GB OC - Corsair Carbide SPEC-01 - EVGA 500+ BRONZE - Windows 10 Pro - Logitech MX Master & K800 Keyboard
My Laptop: Macbook Pro (mid 2010) - C2D @ 2.6GHz - 8GB Apple Ram - Nvidia Geforce 320m 512mb - 850 Evo 120GB + 500GB WD Blue - OS X Sierra
https://linustechtips.com/topic/572450-need-help-with-vb-drop-down-menu/
1 minute ago, mcfly said:
Have you tried using a Select Case with constants set as options in your drop down box?
Nope, do you have example code?
Questions:
  1. Why Visual Basic
  2. Why such an old version of Visual Studio?
  3. What context? WPF & MVVM or WinForms?
  4. If the latter... Why use such deprecated technology?
The single biggest problem in communication is the illusion that it has taken place.
On 26/03/2016 at 7:16 PM, Nuluvius said:
Questions:
  1. Why Visual Basic
I have a 1 word answer for all your questions,
College.
I have no choice, its what my course decides to use. I would choose otherwise what coding language to use.
College.
Are you using WPF or WinForms?
Btw, Visual Studio Community 2015 is free :) Got a ton of cool features.
WinForms, and I am running 2015 community oops my bad.
Edit: I use 2015 at home, I think its a different version of 2015 at college like a paid for license version.
