 I was tired of my LG G PAD V410 being on android 4.4.4. I stumbled across Cyanogenmod 13 which would install Android 6.0 onto the tablet.
So in order I,
  •  Downloaded CyanogenMod 13
  • Downloaded Gapps.zip file for Android Marshmallow.
  • Copy all .zip files to the storage
  • Installed TWRP Recovery on G Pad.
  • Booted into recovery using Flashify
  • hit wipe, cache, data, and  dalvik cach.
  • Installed CM13 and Gapps using TWRP recover.
  • Then I rebooted and it started "optimizing apps"
  • It got to around 126 of 186 and then it went into a loop that says "Unfortunately, Setup Wizard has stopped." then I hit ok and it loops it. So now I am stuck in a boot loop.
So now I tried to do a hard reset with my device, but I cannot seem to get there. I googled it and it says to hold your power down and power button and the recovery screen will pop up but it takes me into regular boot. I am frustrated now because I think I have bricked the device. Any help would be much appreciated. Thanks!
https://linustechtips.com/topic/572203-help-cyanogenmod-13/
14 minutes ago, komputerkid12 said:
its bricked but search google on how to fix it on lg g pad v410 its very important that you say the device model
I managed to get it into my custom recovery boot but I already think I fucked it up so.... Can't get the device model now because I cant get it to boot to view it.
https://linustechtips.com/topic/572203-help-cyanogenmod-13/#findComment-7499361
