Hey everyone, I just got my GTX 980ti Hybrid, but need some help with the radiator installation (never had a liquid cooling anything)
The main question I have is if there's a specific way in wich to fit the radiator.
Tubes on the upper part, lower part, on its side?
Can I set the radiator laying down to push air out of the case through the case floor fan opening?
Or is it the same on any way I put it?
https://linustechtips.com/topic/572172-help-installing-card-cooler/
does not matter
