Just now, psycoUSA said:
My dad put me in-charge of buying a camera security system and I totally know nothing about them so can someone tell me what I need to look in a security system what specs do I need?
Any help appreciated
whats is watching? is it a house? a business? how many places need to be watched? how many cameras are needed?
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/572164-camera-security-system/#findComment-7498965
Budget?
Home or Business?
Footage quality [420, 720, 1080, Full HD]?
Color or B&W?
How much storage is needed - as in how far back does the recording need to be kept? 3, 6, 9 or 12 months?
Continuous or Motion detection recording?
Is night detection required?
Onsite, remote access or both?
 CHRISTIAN MEMBER
https://linustechtips.com/topic/572164-camera-security-system/#findComment-7498990
2 minutes ago, psycoUSA said:
It's a hose and we need +4 cameras
You have many options depending on budget.
This will get you started. Please be aware that price is an easy way to determine quality with these systems. Cheaper the price the cheaper the system.
I strongly suggest researching as much as possible before buying to make sure it suits your needs.
http://www.amazon.com/Amcrest-Security-Weatherproof-Cameras-Transmit/dp/B00PMEG8YQ/ref=sr_1_3?s=security-surveillance&ie=UTF8&qid=1459042254&sr=1-3
 CHRISTIAN MEMBER
https://linustechtips.com/topic/572164-camera-security-system/#findComment-7499016
5 minutes ago, SansVarnic said:
Budget?
Home or Business?
Color or B&W?
I'm not looking for a specific system I want you guys to advice me in what do I need in a system
Btw budget is endless ;)
https://linustechtips.com/topic/572164-camera-security-system/#findComment-7499017
Good things to stick with;
1) 1080p or better for quality.
2) Cameras with Mechanical zoom are better than software zoom.
3) A good quality DVR with enough storage capacity for a minimum of 1 week of continuous recording (I personally recommend about a month minimum).
4) Always use continuous recording instead of Motion activated recording. (uses more storage space but motion has a tendency to miss the importantstuf)
5) Cameras with an IR (infrared) function is always strongly recommended.
6) Color cameras are better, they pick up more recognizable detail.
7) Do not use 180 degree cameras they tend to distort the picture, stay with cameras that max at 135 degree view.
There are more to look for but this is best of the basics to stick with.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/572164-camera-security-system/#findComment-7499066
Thank you very much. I really appreciate that
https://linustechtips.com/topic/572164-camera-security-system/#findComment-7499110
