Does An SSD Help When Modding Games?
Solved by Flowey,
Thing you need to keep in mind is to put all the mods, as well as skyrim, NOT in the 64x/86x program folder with the Steam data folder and keep it in a new folder. Also, keep all your skyrim stuff on the same drive, be it a HDD or a SSD. Performance Wise, your loading are going to fell glorious on that HDD, talking from experience here, maximum loading with about 120 mods is like 7 seconds vs about a minute and a half.
