You really don't need the 950 unless the PCIe transfer speeds are something that you really, really want and are willing to pay for. I don't think there will be major differences between the bootup speeds of either of them.
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
https://linustechtips.com/topic/571789-ssd-help/#findComment-7495567
