I have a lot of love for the Antec ISK-600M case that i have my main PC in, might not be to everyones taste but the horizontal motherboard layout means i can get a full size cooler in there (currently a DH14)
http://www.eteknix.com/antec-isk-600m-micro-atx-chassis-review/
What do you want to put in your case?
Build Log : Red N White Army
System Specs
NZXT S340
i7 4790k
Z97 MSI Gaming 5
Palit 980 Ti Super Jetstream
16GB HyperX Savage 1866 RAM
Samsung 850 Evo 500GB SSD
EVGA 750W G2 PSU
Custom Cooling Loop
https://linustechtips.com/topic/571788-micro-atx-case/#findComment-7495552
How is the cooling in that case?
Give me a boost.
https://linustechtips.com/topic/571788-micro-atx-case/#findComment-7495555
Just now, Zeinone said:
It's cool but kinda ordinary (nothing new) while manta has a cool curve all around the case and comes in more colors. Water cooling friendly and 280mm if I'm not mistaken radiator ready.
I will consider getting NZXT Manta, thanks :)) I wanna other opinions. I am not that much into PC cases :/
Give me a boost.
https://linustechtips.com/topic/571788-micro-atx-case/#findComment-7495558
Just now, huilun02 said:
Depends what type of case you want, and what you going to put in it.
There are the flat compact "console killer" type and bigger cube cases that easily take big coolers.
Heck you could put it in a 900D
I said Micro ATX case. I use stock cooler and have Gigabyte GTX 960, that's it.
Give me a boost.
https://linustechtips.com/topic/571788-micro-atx-case/#findComment-7495560
Enthoo Evolv mATX seems like a super nice case.
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
https://linustechtips.com/topic/571788-micro-atx-case/#findComment-7495570
I think it depends what you want from it. The hard drives and PSU are in a separate compartment in the bottom of the case. The front fan pulls air through directly across the motherboard and then out the back via exhaust. I have a Noctua 14" fan at the front intake and i did have a cougar vertex 12" fan at the back for exhaust which i just had to take out when i installed the DH14 cpu cooler as there wasn't enough space for the cougar between the cooler and the back of the case.
Current temps (no overclock) system temp 27degrees cpu temps 26 degrees (idle/youtube).
I read somewhere that you can get an all in one radiator in here but i don't have much interest in water cooling.
System Specs
NZXT S340
i7 4790k
Z97 MSI Gaming 5
EVGA 750W G2 PSU
Custom Cooling Loop
https://linustechtips.com/topic/571788-micro-atx-case/#findComment-7495571
