Hello,
So i'm looking for a cooler for a cpu i have . It has to :
-be less than 90mm high ( fit in a 2U case)
-fit lga 2011
-allow a TDP of  at least ~155w
-price isn't a concern as of now , but cheaper would be better
Also , it cannot be an AIO.
I've been looking at the dynatron r14 , but it seems loud and my cpu would be pushing it to the limit ( 150W limit )
Is there any other coolers any of you could recommend atm ?
Edit ; realised the r14 only fits narrow ILM on lga 2011 , so that's out .
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/571546-very-specific-cooler/
