Modding PSU conectors
Go to solution Solved by Appelzaadje,
been thinking about that however the cable;s are pretty ok and i can make them custom lenght etc no need imo to get new cables :) im just gona add some sata conectors and move them around a lil
thanx for the confermation that this wont dmg annything
Hey guy's,
Just wondering but why do all the psu manufactorers only put a max of 4 sata conectors on a cabel and place them so far apart. I would like to see like 6 sata conectors on a single cord with closer spacing. Is it wrong to mod these cable's to have more on a single cord? example in the link
http://www.youtube.com/watch?v=Ls14BmwkeWg
Appelzaadje - the Insane
Intel i7-4770K - Maximus VI Formula - Corsair Dominator GT 1866mhz - R9 290X - Xonar DGX - Samsung 840 Pro 256Gb - 3X WD1001FALS - Raven RV01 - Iiyama B2409HDS 3x - Custom water loop - Windows 10 Pro - XFX tripple monitor stand - Steelseries 4HD - Logitech G9, G19, G35 and Z5500
https://linustechtips.com/topic/57098-modding-psu-conectors/
Not really bad, however custom cabling like this needs experience and you need to have precautions in modding cables to not have any electrical accidents.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/57098-modding-psu-conectors/#findComment-772935
Seems pretty straight forward imo just curious to what it does to the 5th or 6th conector on the link will it recive enough power.
https://linustechtips.com/topic/57098-modding-psu-conectors/#findComment-772941
Most likely, SATA doesn't need that much power to be honest.
https://linustechtips.com/topic/57098-modding-psu-conectors/#findComment-772947
If PSU is a quality one then they all will get the same "power". Ive done a SATA power for R3 fit and now im on Prodigy and distance between the 2 HDDs dont match and need to use some old standard ones. Part is ive only did 2 connectors and not 6.
Mostly you need basic know-how, tools and measurments.
<p>Eryi's Action Rule#2 - "Dont jump on the green mushroom"
Ministry of StopIt!
https://linustechtips.com/topic/57098-modding-psu-conectors/#findComment-772951
im planning to do 2 extra on 1 cable to make it 6 total but main point is i want them closer together to get a nicer cable route think an AX850 will be good enough to do this consistantly
https://linustechtips.com/topic/57098-modding-psu-conectors/#findComment-773058
If it was me i would make whole new cable with fixed lenght and sata connectors in place to perfectly fit in HDD/SSD locations.
Do measurments and look will they fit in existing one.
Ministry of StopIt!
https://linustechtips.com/topic/57098-modding-psu-conectors/#findComment-773082
https://linustechtips.com/topic/57098-modding-psu-conectors/#findComment-773240
