Hello! I'm looking for a new laptop to replace my old MacBook and I am kinda overwhelmed by choice. I would like your help to help me distinguish the good from the bad. I would like it to have a pretty good performance cpu and gpu. (For the cpu, in thinking about 2.5ghz, and for the gpu, hopefully better than a gtx 960m) and 16gigs of RAM. I would like it to be capable or playing medium to intense demand games. I would like it to be large at about 15 to 18 inches, and about 2 to 2.5 kg(5.5 to 7 pounds) and my budget is 1400 to 1900 US dollars. Thank you for any help and suggestions!
https://linustechtips.com/topic/570709-need-help-choosing-laptop/
Do you actually need something you can move around? Because if not Desktops are the way to go since you get more performance per dollar.
Reliable $550 Starter PC (http://pcpartpicker.com/p/KGgpZL) *Just waiting for someone to need help with there ram so I can make a downloadmoreram.com joke*
http://portablepicker.com/part/msi-laptop-9s716h212052
http://portablepicker.com/part/asus-laptop-g752vldh71
http://portablepicker.com/part/acer-laptop-g959170xr
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
33 minutes ago, technospaceface said:
Yes, I need something portable. If you have any more questions, feel free to keep asking them.
Any other requirements you need for a laptop? Like battery life and what nots
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
