Hey people of LinusTechTipsForums. I need some help trying to enable Nvidia SLI but for whatever reason I just can't get it to work.
Here are my PC Specs CPU: i7-4790k Motherboard: ASUS Z97-A RAM: 16GB Crucial Ballistix Sport PSU: Corsair CX750M Storage: 240GB SSD + Other HDDs GPUs: ASUS GTX 970 STRIX + EVGA GTX 970 SC
I hooked up the two GPU's like you normally would in an SLI configuration, but for whatever reason in Nvidia Control Panel the "Disable SLI" bubble is filled in by default, and the "Maximize 3D Performance" bubble is greyed out. I get an error message saying "To use Maximim 3D Performance, connect the SLI-Ready graphics cards with an SLI connector." I did indeed connect an SLI bridge to those two cards, and for whatever reason I still can't enable SLI. Both of the cards are in working condition, and they do show up in programs like MSI Afterburner which means that my system does recognize that they're even there. I have no idea what to do from here, and looking at old online threads regarding SLI doesn't help.
GPU-Z does recognize both of the cards, and they are both running at 8x.  Both graphics cards are running in the top two PCI Express slots. (The slot all the way at the bottom doesn't have enough clearance) I have tried switching their positions and it still doesn't work. I have also tried switching the position of the SLI Bridge and it still doesn't work. Please help.
https://linustechtips.com/topic/570624-sli-problems/
Do you have a second SLI bridge you could try using?
Also try taking out any other PCI-E things you might have and check the BIOS for a setting (Might not be called SLI, could be like multi gpu support or something)
CPU: i5-4690K @ 4.0GHz GPU: Gigabyte Gtx 970 WindForce MOBO: Gigabyte Z97 Gaming-3 CASE: Corsair Carbide 200R PSU: Corsair RM750
RAM: Corsair Vengeance 4GBx4  MOUSE: CM Mizar KEYBOARD: Logitec G110
https://linustechtips.com/topic/570624-sli-problems/#findComment-7484952
I unfortunately do not have a second SLI bridge I could use. All other expansion slots are clear except for those two graphics cards. I'll definitely try looking in my BIOS for a setting like that. Thanks so much for the advice. I'll reply back as soon as I get back from searching my BIOS.
https://linustechtips.com/topic/570624-sli-problems/#findComment-7484979
Cool, if not there isn't a setting, or it's on, It's time to try update all the drivers, video cards and bios
https://linustechtips.com/topic/570624-sli-problems/#findComment-7484985
There wasn't a setting for enabling SLI in the BIOS. My drivers are all up to date as well. (GeForce Experience automatically updates drivers so I assume I'm up to date.) Anything else I could attempt?
https://linustechtips.com/topic/570624-sli-problems/#findComment-7484994
At this point I'd go find the cheapest SLI bridge I could, just to see if it works.
I found this too: http://nvidia.custhelp.com/app/answers/detail/a_id/782/~/sli-troubleshooting-tips
https://linustechtips.com/topic/570624-sli-problems/#findComment-7485010
Well I was hoping that I'd be able to solve this tonight.Oh well. Thanks so much for the help and I'll definitely try to find an extra SLI bridge.
https://linustechtips.com/topic/570624-sli-problems/#findComment-7485014
Double check video card boxes/motherboard boxes, I got one with my gigabyte 970 and my motherboard
https://linustechtips.com/topic/570624-sli-problems/#findComment-7485039
1 minute ago, It'sMeChipzy said:
I did. I actually trolled myself twice thinking I found some extra SLI bridges. They were actually Crossfire bridges...
Oh that's annoying :P
https://linustechtips.com/topic/570624-sli-problems/#findComment-7485045
Check out this thread on the EVGA forums, as the poster had a similar issue. Perhaps the fix will work for you, as well. Good luck, and get back to us with any new developments! http://forums.evga.com/Cant-enable-SLI-with-EVGA-GTX-970s-and-Asus-z97A-m2255376.aspx
https://linustechtips.com/topic/570624-sli-problems/#findComment-7485063
It didn't work for me. I'm just about to go make the 20 mile drive to the nearest electronics store that carries SLI bridges.
https://linustechtips.com/topic/570624-sli-problems/#findComment-7487637
