Anything under 1.3V.  You won't damage the card on the stock BIOS anyways.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/570518-safe-voltage-for-980ti/#findComment-7483884
Good also right now I am testing some overclocks but every stress test or burn in test only says I am using 60%tdp or the core clock is 595 and mem at 6610 when I have it overclocked to 8.95 on mem and 1461 on core. Why is it saying that it isn't using those settings?
https://linustechtips.com/topic/570518-safe-voltage-for-980ti/#findComment-7483894
You're probably trying to dial in an overclock that is too high.  What numbers are entered into the software you use?
https://linustechtips.com/topic/570518-safe-voltage-for-980ti/#findComment-7483920
5 minutes ago, Seri said:
Did you have one of those "the driver stoped working and had to be restarted" messages? If yes you need to restart, most of the times this error locks your card to stock settings untill the restart. If not, what perfcap does GPU-Z show you?
nope, perfcap?
https://linustechtips.com/topic/570518-safe-voltage-for-980ti/#findComment-7483958
Just now, Marcus Torre DeProspero said:
I am only trying to hit 1400mhz and it is pushing it down to 595
Remember that your card will still boost too.  +180Mhz on the core should allow it to boost up to over 1500Mhz.
https://linustechtips.com/topic/570518-safe-voltage-for-980ti/#findComment-7483963
I am only trying to hit 1478
1 minute ago, Beeeyeee said:
if you try to clock it too high it'll default to something werid and low.. at least thats what it did for me and whenever you try to change anything it'll go straight back to it. the only way i fixed it would be to restart
Restart what?
https://linustechtips.com/topic/570518-safe-voltage-for-980ti/#findComment-7483978
Restart what?
What settings are inputted into the overclocking program?
https://linustechtips.com/topic/570518-safe-voltage-for-980ti/#findComment-7483992
i really really doubt that the card can hande a 1200 MHZ Ram overclock ( or is this the standard factory overvlock for this card?). Also you did not increase the max voltage to the core so that might be one of the reasons. Try running a benchmark and make a screenshot of GPU-Z while doing so.
https://linustechtips.com/topic/570518-safe-voltage-for-980ti/#findComment-7484019
1 minute ago, Seri said:
i really really doubt that the card can hande a 1200 MHZ Ram overclock ( or is this the standard factory overvlock for this card?). Also you did not increase the max voltage to the core so that might be one of the reasons. Try running a benchmark and make a screenshot of CPU-Z while doing so.
I did before and I have been able to reach 9ghz on the memory before
https://linustechtips.com/topic/570518-safe-voltage-for-980ti/#findComment-7484027
