I just build this PC like 2 hours ago. I have just got done  with all the drives and I want to go to Spotify to listen to music but is says
The peripheral does not appear to be plugged in. Check the connection.  Proceed to next step to finish
So I go to the next step and I get
The speaker, headset, or headphones are unplugged, when they aren't!
Any fixes??
EDIT: I am using Windows 10
https://linustechtips.com/topic/569952-new-pc-audio-help/
29 minutes ago, PooPipeBoy said:
If you're using onboard audio, are motherboard drivers installed?
In case you've got a high-end sound card, the card may require a 4-pin molex connection.
Sir come back. I just got the drivers. It still isnt working. I have restarted and all. No sound card or anything
https://linustechtips.com/topic/569952-new-pc-audio-help/#findComment-7478463
Sure. Can you double check if the onboard sound is enabled in the BIOS? It may be automatically disabled by default or something weird.
https://linustechtips.com/topic/569952-new-pc-audio-help/#findComment-7478725
right click the speaker icon in the right of the start bar go to playback devices are thing enabled. If you cant see anything in that box right click again show disabled, start enabling stuff then click on them and hit test until you hear a noise.
The Dick of the audio page!
https://linustechtips.com/topic/569952-new-pc-audio-help/#findComment-7480575
