If i am on a budget and want upgradibility with modularity, is it worth getting a modular 650w PSU now or getting non modular low capacity PSU one now and upgrading later
now I am getting a GTX 960 and later going to upgrade to GTX 980ti
I am getting an i5-6500 and then getting i7-6700k later
IS IT WORTH?
https://linustechtips.com/topic/569939-budget-modular-psu/
IS IT WORTH?
If you can afford to get a high quality one to start then do that, as it will be more efficient and a lot less likely to totally fail and die on you than something super cheap. Here's a list of a ton of good quality PSU's (not all of which are super expensive) that won't blow up your system.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/569939-budget-modular-psu/#findComment-7478286
4 hours ago, Afro_Lamb said:
going to upgrade to
Well my internet is refusing to let me quote more than just this snip of your post so OK
Yes, a 650W PSU is fine for both now and later, however I doubt you're gonna find the funds to jump from a 960 to a 980ti within the remaining time this generation of Nvidia cards has remaining. I could be wrong though. Check out the PSU whitelist in my sig for some good PSUs. I'd recommend the EVGA G2 for what you want from a PSU.
https://linustechtips.com/topic/569939-budget-modular-psu/#findComment-7479137
Invest in a quality PSU now, this is one area where people often think they can cheap out but it really is good to invest in a high quality power supply that will provide clean power to your parts and have a lower chance of failure or housing remodel due to fire.
The 980ti requires a 600W power supply (according to various manufacturers) and the newer card that are coming out will likely have an even lower power consumption.
浪速の建てるは静か用に建てました!- Build Log Coming Soon!
https://linustechtips.com/topic/569939-budget-modular-psu/#findComment-7479224
what gpu would i get as the money going to the PSU is really gonna rack up the price with the price of the gpu (in GBP)
https://linustechtips.com/topic/569939-budget-modular-psu/#findComment-7482242
You would get whatever the next generation of Nvidia cards 980ti equivalent is.
https://linustechtips.com/topic/569939-budget-modular-psu/#findComment-7482842
