hi guys , i am planning to buy xaomi redmi note note 3
but i am worried that it has not great protection on screen and the whole body
i dont have slipry hands but i am worried that a dent on a phone or screen will compromise the experience
i am planning to buy a good protective case and screen guard http://www.flipkart.com/tarkan-shock-proof-case-xiaomi-redmi-note-3g-4g-prime/p/itmeebkjhpv5w2ba?pid=ACCEEBKJPV2TJSPK&ref=L%3A926566112453806939&srno=p_6&query=redmi+note+3+cover&otracker=from-search
any suggestions
https://linustechtips.com/topic/569814-redmi-note-3/
I suggest not getting such an ugly case.
But if your phone is going to be plastic, just get like a screen protector. If your screen is going to break, it will happen with or without a case. Impact from the sides or back is less likely to shatter the screen as a minute impact on the surface of the screen.
If there is metal on your phone, I suggest a case because dented metal doesn't look good. But neither does an ugly case.
I really like 2 part cases, with a rubber part and plastic shell. I use one on my galaxy note 4, the spigen slim armor.
https://linustechtips.com/topic/569814-redmi-note-3/#findComment-7476899
Been using redmi note 3 pro, for about a week and a half now. The only thing i bought for protection, is a cheap "tempered glass" for the screen. The new metal body, seems similar in quality with iphone 6 / 6s metal body. Haven't seen any significant scratch mark on the body.
https://linustechtips.com/topic/569814-redmi-note-3/#findComment-7500037
