The other day I posted a thread here regarding ASIC quality and was met with a wide range of people saying it doesn't matter. Some did say it does have an effect to a degree but most people started to have a b!tch at them saying it does. Well for some reason I beg to differ now the reason I say this is because EVGA on there website you can now buy a GPU depending on its ASIC quality. Now an international company wouldn't do this if it doesn't have some noticeable effect on performance I have in cluded the link so people can have a look then maybe buy.
http://eu.evga.com/articles/00944/EVGA-GeForce-GTX-980-Ti-KINGPIN/#BuyNow
https://linustechtips.com/topic/569800-asic-quality/
Yes, Asic quality does matter.
Current Build: Core i7 4790k @ 4.6, Asus Maximus VII Hero, Corsair Vengeance Pro 2400mhz 8gb (2x4gb), GTX 980ti, NZXT Kraken X61, Fractal Define R5  EVGA Supernova B2 850w, Some 300gb hard drive.
http://pcpartpicker.com/p/W7CNrH
https://linustechtips.com/topic/569800-asic-quality/#findComment-7476643
Jay two cents has a video about this, saying asic doesn't matter on oc, it's just the effeciancy of the chip as far as leakage of current, you will need more volt for oc on low asic chips, but doesn't affect overall oc ability, I have a 92 asic on my gtx980, can't oc worth shit lol
https://linustechtips.com/topic/569800-asic-quality/#findComment-7476693
I believe it generally has more to do with voltage leakage. The higher the ASIC Quality, generally less voltage is needed for the same clock speed. It might affect overclocking somewhat, but doesn't have a direct correlation to overclocking since lower voltages isn't the only thing that gives better overclocks on a chip. I think that's what it's supposed to mean.
The technical definition (in my opinion) is :
ASIC=Application-Specific Integrated Circuit
Therefore ASIC Quality is the quality of your GPU (the die itself, not the circuitry and power delivery stuff)
Which means that probably higher ASIC quality=less voltage needed for same clock speed (for the most part)
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/569800-asic-quality/#findComment-7476701
IMO the real reason they are selling different ASIC qualities is because people who don't know what they are doing will look at the higher percentage and instantly think 'Oh a card with 80% must be better than a one with 60%' and spend more of their hard earned money for some supposed performance bump.
https://linustechtips.com/topic/569800-asic-quality/#findComment-7476708
The ASIC quality of a card, is reading the voltage leak in the core. It doesn't, however, account for the rest of the components on the card. The VRM quality, PCB quality, chokes, caps. memory type, power delivery and about a hundred other things will play into how well a card will overclock.
All things being perfectly equal between two cards, the card with the lower ASIC will require a higher voltage to reach a specific clock than the card with the higher ASIC.  All of these things, however, are never equal between two cards, even of the same model number.
Realize too, that with Maxwell, the temps the card is running at will play a HUGE part in the max overclock.  The hotter it is, the lower the boost will be.  Likewise, the cooler the card is, the higher the boost will be.  Overclockability of the card, also has to do with the "overclockers" ability, and willingness to use custom bios files and increased voltages.
SO...is ASIC quality EVERYTHING?  No....but it IS a pretty good indicator of what that specific core will be capable of in the right hands, with the right cooling.
CPU: Ryzen 1600X @ 4.15ghz  MB: ASUS Crosshair VI Mem: 32GB GSkill TridenZ 3200
GPU: 1080 FTW PSU: EVGA SuperNova 1000P2 / EVGA SuperNova 750P2  SSD: 512GB Samsung 950 PRO
HD: 2 x 1TB WD Black in RAID 0  Cooling: Custom cooling loop on CPU and GPU  OS: Windows 10
https://linustechtips.com/topic/569800-asic-quality/#findComment-7476761
5 minutes ago, Vellinious said:
DELETE
https://linustechtips.com/topic/569800-asic-quality/#findComment-7476778
ASIC doesnt matter. Its just marketing to get more of your MoneyzzzZZzzz.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/569800-asic-quality/#findComment-7476811
Ugh
https://linustechtips.com/topic/569800-asic-quality/#findComment-7477571
