PSU HELP
Go to solution Solved by STRMfrmXMN,
4 minutes ago, Andre Cunha said:
So im going to build a new pc amd i was wondering what psu should i choose. It has to be less than 100 but good enough to power my build.
This is my build:
http://pcpartpicker.com/p/qdk7cf
Thank you
Ditch the 212 if you're using a locked i5 (which you are) so you can squeeze a 120GB SSD in there and an Antec HCG, EVGA B2/GQ, Seasonic G-series as your PSU.
Just now, Rolfejc said:
The Evga G2 550 watt unit is the best option.
http://pcpartpicker.com/part/evga-power-supply-220g20550y1
Man people always beat me to it!
Kek
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
https://linustechtips.com/topic/568966-psu-help/#findComment-7468326
I second that.
// Floatplane Pilot //
Main Rig:  Motherboard: ASUS H270 - PLUS - CSM | RAM: Corsair Vengeance DDR4 16GB (2x8GB) | Case: Corsair Carbide Series SPEC - 02 | SSD: ADATA SU800 128GB HDD: WD 1TB Hard Drive | PSU: Corsair CX 550M | CPU: Intel Core i7-7700 Cooling: Cooler Master Hyper 212 EVO | GPU: ASUS GeForce GTX 1070 | Keyboard: Logitech G710+ Mechanical | Mouse: Razer Naga 2014 | Sound: Corsair VOID RGB / USB Headset | OS: Windows 10
Laptop:   Razer Blade Stealth 2016
https://linustechtips.com/topic/568966-psu-help/#findComment-7468329
This is my build:
Thank you
https://linustechtips.com/topic/568966-psu-help/#findComment-7468351
1 minute ago, Andre Cunha said:
And I could ditch the 212 but its so cheap........... >D
You don't gain anything from it so you might as well not buy it and get better performance elsewhere by having an SSD.
https://linustechtips.com/topic/568966-psu-help/#findComment-7472837
