Ok, so sometimes (quite frequently actually) I loose completely WAN connection. I use an ASUS router 3in1. The firmware of the router says then that the networking cable is unplugged (though it's plugged in). I know how to fix it, becuase when I unplug the LAN to my PC and reset the router i have conection again. My question is why does it keep on happening? And if there is a way to prevent it? Thanks in advance.
https://linustechtips.com/topic/568665-help-internet-keeps-messing-up/
seems like there is a problem with ur Ethernet cable, try another one?
Forgive my bad English. Im Indonesian
kalo ada yang indo juga :v halo bro
This ^^
I had the same problem a few weeks ago and changing the ether fixed it.
*mildly autistic*
CPU: Intel Core i7-5820K @ 4.2 GHz | Motherboard: x99 RampageRAM: 16GB DDR4 GPU: Nvidia 980 Ti SSD: Looking for one |
2 minutes ago, OxFox333 said:
Well I could try that, I need a long one though not that I have one laying around so maybe tomorrow c;
okay :D might try a shorter cable with laptop instead (if you have) to speed up the troubleshooting.
