[Java] ArrayList element operation issue
Solved by highonquack,
Try this
ArrayList<int[]> x = new ArrayList<int[]>(); x.add(new int[] { 0, 0 }); // breakpoint 1 int[] y = new int[2]; y[0] = x.get(0)[0]; y[1] = x.get(0)[1]; // breakpoint 2
Objects are passed by reference in Java. So when you set y equal to the first array in the list, it passed you a pointer/reference to the array that was inside of the ArrayList.
