For some reason this does like absolutely nothing. The print statement comes up and I type a random letter, but when I enter I just get an endless amount of blank lines.
post-33018-0-57683000-1379285032_thumb.p
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/56810-c-programming-help/
What are you going to be using this for?
It's college work. I can't figure out why my output isn't working.
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768141
Well whats up with the scanf? it seems to have input| or something, not an array index. If you are only going to be working with one value I wouldn't even bother with an array index myself.
My rig: 2600k(4.2 GHz) w/ Cooler Master hyper 212+, Gigabyte Z68-UD3H-B3, Powercolor 7870 xt(1100/1500) w/AIO mod,
8GB DDR3 1600, 120GB Kingston HyperX 3K SSD, 1TB Seagate, Antec earthwatts 430, NZXT H2
Verified max overclock, just for kicks: http://valid.canardpc.com/show_oc.php?id=2609399
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768145
I thought char needed a limit on its input? So that's why I put 1 there :P
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768179
Funny thing is, as I recall, C does nothing to babysit you. So even if you have an array there is no reason that you can't address a value outside the array. Or even negative values. But as you could imagine those are generally a very very bad ideas.
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768212
isn't the value stored in [0]
I've not coded in c for quite a while, but in a lot of other languages, you wouldn't need an array
[spoiler=»--((¯`·._.·¤~●oO му яιg Oo●~¤·._.·´¯))--«] Case: Corsair 600T White       CPU: Core i7 3930k @ 4.3GHz                     SSD: Crucial M500 480GB
MB:    Asus P9X79 LE         GPU: Nvidia GTX 780 Reference             HDD: WD Caviar Green 3TB
PSU:   Seasonic X-1050      RAM: G.Skill Trident X 32GB @ 2.4GHz   ☃ There are 10 types of people in this world. Those who understand binary and those who don't.
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768217
If you only want to grab a single character you don't need the array index on the input variable. The main problem is that you are reading input[1] this won't work because in C array indices start at 0 (so in this case input[1] will give you an undefined value as it is outside of the array)
You should also set the value of the input variable when you define it, otherwise it will be an undefined value until you set it to something (so there's a small chance it could be set to 'x' before you read anything).
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768235
@Flojer0, @Prince32780, @random314
I changed all the input[1] to input and initialized input as 0, but well this happens:
Lab3$ ./switch
Please type a character [A-Z or a-z] ('x' to exit): a
x
Segmentation fault
I tried typing a then I kept hitting enter....then I hit x just to see what happened.
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768243
Have you replaced all occurences on input[1] with just input?
Also you should put a space before the conversion specifier in scanf, because it won't strip leading whitespace from the standard input.
Yes I did. I still get nothing
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768316
the | after input is unnecessary
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768318
you are missing a lot of quotes
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768328
#include <stdio.h>int main (void){        char input;    input = 0;    while (input != 'x'){        printf("Please type a character [A-Z or a-z]");        printf(" ('x' to exit): ");        scanf( "%c \n", &input );//  Use switch statements to determine output        switch (input){            case 'x':            break;            case 'a' : case 'e' : case 'i' : case 'o' : case 'u' :            case 'A' : case 'E' : case 'I' : case 'O' : case 'U' :            printf("%s is a vowel\n", input);            break;            default:            printf("%s is a consonant\n", input);            break;        }    }}
this compiles, but I think something is missing
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768337
That's not a pipe, it's just where I was last typing lol.
I'll see what you changed and see if it makes a difference.
You're missing a return 0; at the end lol. Besides that, that's exactly what I have :3
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768346
Just noticed that the format specifiers at the bottom need to be %c not %s (%s is for a null terminated string of characters, so since it couldn't find a null it just keeps reading until it goes into some part of memory it shouldn't be in, which makes it generate a segmentation fault)
Like this:
#include <stdio.h>int main (void){        char input;    input = 0;    while (input != 'x'){        printf("Please type a character [A-Z or a-z]");        printf(" ('x' to exit): ");        scanf( " %c", &input );//  Use switch statements to determine output        switch (toupper(input)){            case 'x':            break;            case 'A' : case 'E' : case 'I' : case 'O' : case 'U' :            printf("%c is a vowel\n", input);            break;            default:            printf("%c is a consonant\n", input);            break;        }    }    return 0;}
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768367
why aren't you using pointers
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768368
I was actually playing around with that whilst I took the SS.
How?
Lab3$ ./switch
s
a is a vowel
Please type a character [A-Z or a-z] ('x' to exit): s
s is a consonant
Please type a character [A-Z or a-z] ('x' to exit): d
s is a consonant
Please type a character [A-Z or a-z] ('x' to exit): c
d is a consonant
Please type a character [A-Z or a-z] ('x' to exit): f
c is a consonant
Please type a character [A-Z or a-z] ('x' to exit): ^C
Lab3$
^ what happens when I use all %c
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768390
if this was java or c#, it'd be much easier :P
c likes to compare integers in switch statements
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768410
The code I posted above shouldn't have a newline in the scanf statement I've fixed it now
Alright so can I not use default for all of the consonants? Because it prints is a consonant for every single one of them too.
Lab3$ ./switch
a is a vowel
 is a consonant
s is a consonant
 is a consonant
d is a consonant
 is a consonant
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768418
The scanf statement also needs a leading space.
Also you shouldn't use default for all the consonants anyway, what happens if what you type is neither a vowel nor a consonant?
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768441
OMG THANK YOU IT'S FIXED!
Thanks all of you, I stare at these things all day and it's always the minute details :P
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768447
3 is a consonant.
https://linustechtips.com/topic/56810-c-programming-help/#findComment-768450
