PS4 Powerline Help
Solved by tarfeef101,
Couple thing: One, check in your router to make sure that they are not trying to use the same IP address. If they are, that would explain all the problems. If so, I can help you fix that issue (just confirm that is the problem). If not, ensure that none of the adapters are in power bars or UPS systems, and if you have the powerline network secured, unsecure it and try again. Also, make sure the adapter going in to the modem/router is plugged in first, then plug in the other two, and make sure both connect to the first node. There may be some compatibility issues, but that is very unlikely. Once you've tried all these things come back with what has changed and what you observed.
