Help With First Build
Go to solution Solved by Excon,
I know the voltages because right now my classifieds are stuck to that limit and my cpu to reach 4.8 to 5ghz would take around 1.4v to get those speeds. These are rough guesstimates.  :)
Ahh, either way you will be fine with those rads especially because they're thick rads.
Hey guys I am begining my first dive into water cooling and have some questions.
1) Would a 360mmx60mm and 240mmx45mm rad be enough for a 3570k at 1.4v and 2 evga gtx 780 classifieds at 1.35v to 1.45v
2) Are there differences between cpu blocks in terms of temps
3) What are good fans. I heard that cooler master sickle flows and noctua nff12 are good fans.
Thanks
https://linustechtips.com/topic/56722-help-with-first-build/
1. Yes, depending on fans and what RPM but you'll be fine
2. No, pick your favourite look
3. Sickle flows suck, Noctua's are great. Scythe Gentle Typhoons and Swiftech Helix's are also great.
Also how do you know what voltages you will need? 1.4v on a 3570k means basically 5Ghz range....
https://linustechtips.com/topic/56722-help-with-first-build/#findComment-766585
https://linustechtips.com/topic/56722-help-with-first-build/#findComment-766639
https://linustechtips.com/topic/56722-help-with-first-build/#findComment-766651
