Help finding a good UPS
Go to solution Solved by W-L,
1 hour ago, lubblig said:
I wasn't able to find the one you linked on any reputable sites in Sweden, although I did find this:
http://www.apc.com/shop/se/sv/products/APC-Power-Saving-Back-UPS-ES-8-Outlet-550VA-230V-CEE-7-7/P-BE550G-GR
Which seems to be pretty much the same thing but a new generation/higher model perhaps?
Would that be a good choice?
That is just a slightly larger more powerful model but should be more than enough for the NAS and some other equipment if desired. Both do also have the USB connectivity option to safely shut down the server during extended power outages if needed.
I need a rather low-end UPS. I'm going to use it with a backup server I've built that uses about 40-60watts (idle-full load) and is almost always idling. What I want it to do is provide clean power (sine wave) to the computer, since at my friends house, for some reason the computer doesn't like it being sort of inconsistent (I don't know what it is, but I have some issues that, from my research has to do with the power not being a 100% all of the time). Therefore I'd like a ups that can clean it up and provide a battery backup if the power were to go out. Though I do not need for the computer to stay on once the power has gone out, so if the power does go out and the UPS detects this, I want it to, automatically, turn the computer off. It's really just to protect the data on the hdd's from potentially going corrupt if the power outage is during a file transfer.
  • So, the power usage of the computer is low, therefore I do not need a big battery.
  • I want it to give the computer better/cleaner power than it gets now.
  • And I want it to be able to connect via usb to the computer and be able to turn the computer off if the power goes out. (Also, if it matters, it needs to work in Sweden, here is some info on electricity and plugs used in Sweden)
  • Also, I want it to be rather cheap (although not so cheap the it becomes garbage)
I currently do not have a budget to go by, I kind of want to get a feeling for how much I will have to spend to get a decent ups that can do the above and see if it's even possible to me (meaning, what I'd consider acceptable for what I get). But again, the battery really doesn't have to be anything big, I just want certain features, as described above.
System:
i5 3570k @ 4.4 GHz, MSI Z77A-G43, Dominator Platinum 1600MHz 16GB (2x8GB), EVGA GTX 980ti 6GB, CM HAF XM, Samsung 850 Pro 256GB + Some WD Red HDD, Corsair RM850 80+ Gold, Asus Xonar Essence STX, Windows 10 Pro 64bit
PCPP:
http://pcpartpicker.com/p/znZqcf
https://linustechtips.com/topic/567048-help-finding-a-good-ups/
I prefer fed ex.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/567048-help-finding-a-good-ups/#findComment-7448966
2 minutes ago, lubblig said:
-SNIP-
Something like this from APC would be good for a low power systems another good option is Cyberpower:
http://www.apc.com/shop/se/sv/products/APC-Back-UPS-400-230-V-tyska-och-nederl%C3%A4ndska/P-BE400-GR
https://linustechtips.com/topic/567048-help-finding-a-good-ups/#findComment-7448986
System:
PCPP:
https://linustechtips.com/topic/567048-help-finding-a-good-ups/#findComment-7449174
https://linustechtips.com/topic/567048-help-finding-a-good-ups/#findComment-7449632
Thanks, I'll get it and see if it works like I hope it will.
System:
PCPP:
https://linustechtips.com/topic/567048-help-finding-a-good-ups/#findComment-7449669
