I'm hoping to build a super budget NAS and I'm wondering if I can pick up a switch instead of splashing out on a multiple port network card. Is it possible to do this?
i5 6600K @ 4.4GHz / Cooler Master Nepton 240M (GC Extreme Thermal Compound) / Asus Maximus VIII Gene / 8GB Corsair Vengeance LPX DDR4-2400 / 240GB SanDisk SSD Plus & 2TB SeaGate Barracuda HDD / EVGA GTX 980 ACX 2.0 / XFX XTR 750W 80+ Gold  / Fractal Design Node 804        Total: £1042.31
https://linustechtips.com/topic/566559-switch-as-a-network-card/
They have two different uses and will effect the speeds going to and from the NAS. The switch will allow networking, the card just allows the PC to connect to two networks essentially.
What is your budget and uses?
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443319
If you are planning on being able to access it on the network than that should work fine.
|My Rig| |Intel Core i5-6600K @ 4.70GHz| |GT 740| |16GB Kingston HyperX Fury 2133MHz| |240GB PNY SSD, 1TB WD Blue (RAID 0), 320GB Backup Drive| |Corsair 600C| |EVGA Supernove 850 G2|
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443320
You want to know if you can use a switch as the NAS's network card? No.
If the mobo for the NAS does not have a NIC build into the mobo (never heard of that), then you will have to use a PCI or PCIe NIC in order to have it interface with the network.
Or am I misunderstanding what you are asking?
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443329
Around £250 for the whole thing. I will just use it for mass storage and backups.
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443334
I was thinking of connecting my PC to the NAS directly for amazing speeds.
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443341
So I'm assuming home use?
You mobo should have 10/100 or 10/100/1000 port built in, you only need 1 for the NAS unless its going to multiple networks.
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443345
You need a switch not a card
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443352
Cards allow the device to connect to the network, not back and forth between computers. Switches bridge that or special cables. If you buy a gigabyte(10/100/1000) switch you'll have more speed than you could need.
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443371
Is this one any good?http://www.amazon.co.uk/TP-LINK-TL-SG1005D-V6-Ethernet-Unmanaged/dp/B00ZOOJXEG/
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443377
Your bottleneck will always be at the single weakest point. If you are planning to do something like this a quad network cards can be very cheap such ashttp://www.ebay.co.uk/itm/Intel-Gigabit-ET1-Quad-Port-Server-Adapter-network-adapter-/291710733794?hash=item43eb508de2:g:8twAAOSw4UtWRQp6
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443386
5 minutes ago, BluPaperclip said:
That one should work fine
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443408
Oh, ok.
Yes, in that case you will want a switch.
END OF LINE
https://linustechtips.com/topic/566559-switch-as-a-network-card/#findComment-7443439
