Receiving with Arduino
Go to solution Solved by manikyath,
1: the arduino can get a USB power in, or a 7-15 volt (off the top of my head) input voltage.
2: reverse engineering protocols, look into documentation if avaliable.
3: yes, see 2
4: the cheapest that wont catch fire from the amount of leds that you hook up. probably gonna be a PNP/NPN transistor because you can get those for next to nothing.
So I am starting to experience with RGB leds that are controlled with Arduino. And here is list of things I need help with:
1. How to power Arduino inside of the PC.
2. How to get signal from basic 5050 RGB strip.
3. Is it even possible to copy RGB signal from more advanced strips like Hue+ and ws2800-series.
4. What kind of Mosfet (or similiar) should I use for the main power of the strips.
Thank you!
https://linustechtips.com/topic/566486-receiving-with-arduino/
3: yes, see 2
https://linustechtips.com/topic/566486-receiving-with-arduino/#findComment-7442424
3: yes, see 2
I cant find any reverse protocol thingies for the arduino, any suggestions?
https://linustechtips.com/topic/566486-receiving-with-arduino/#findComment-7444086
thats because you're not reverse engineering the arduino, you're using the arduino to reverse engineer the rest.
https://linustechtips.com/topic/566486-receiving-with-arduino/#findComment-7444097
I have been looking into few tutorials and such during last few days and almost everything is clear now, expect:
1. Will my Arduino burn down if I connect 5A (5000mA) led to be the input?
2. Which input pins should I use? Analog or digital? (Hue+ will be the input)
https://linustechtips.com/topic/566486-receiving-with-arduino/#findComment-7450550
