Yesterday, I finally began playing The Witcher 3. As i played for about 2 hours I was strictly Geralt. Everything was good. Running at 60-75 fps on High On my GTX 970
Well... Today I started playing as Ciri And well... You could say the experience was less favorable. Huge FPS drops when i logged in I was getting low 40s. I bumped everything to Low
And i was lucky to get low 50s...
After looking at the GPU it was cranked to 99% But only using about 800-1000MB Of Memory. Which is odd.
What is going on? And why is the performance so vastly worse than yesterday... Any Ideas would be appreciated.
  • CPU: E3-1241v3|| MOBO: Asus B85M-G R 2.0|| RAM: Crucial Ballistix Sport (4x4) 16GB || GPU: MSI Geforce GTX 970 Gaming || CASE: Corsair 100R Carbide Series || Crucial MX100 250GB SSD + WD Blue 1TB || PSU: Sentey 750W Semi-Modular 80+ Bronze || Cooling: x2 Corsair AF120 Red LED Silent Edition
https://linustechtips.com/topic/566183-witcher-3-memory-usage-issue/
Sounds normal, if you don't have an FPS limit your GPU will usually be pinned at 100%
Something else must have been affecting it.
Check out the graphs in MSI afterburner and see if anything else is maxed out (possibly the CPU)
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
I'm just curious as to why the performance is so much worse than yesterdays. If this was a norm for the 970 I would be fine with it. But its running so slow it seems.
Hopefully Afterburner will shed some light on it
